1985 Johnson 50hp shift rod height
Auxlarry
Can't pull up the brp site.....Is it electric or manual start? Short or long shaft?
Honorary Supreme Mariner
This info is in the top secrert files on this page or simply ---google---johnson shift rod height---it is all there for you.
alfajeffrey
ok I figured it out. I got everything back totogether, and I was able to get it started. It dies out after little while. Im guessing everything needs to be adjusted. I have one problem. My fuel pump is mounted on the air box, but the powerhead I put on had the fuel pump mounted on the crank case. So my vacuum line is not connected. How can I get a vac line to my fuel pump? My old powerhead had a nipple to connect to, and this one doesn't.
If the fuel pump is mounted correctly on the block you do not need a seperate pulse hose.---The pump should be mounted over the pulse hole on the block with a gasket !!!
alfajeffrey
Ya I stuck a barb with a hose and ran it to my fuel pump and it's working better. For some reason it is mounted on the air box. What is the best way to check for air leaks in the fuel system? I held my thumb over the main line and I saw bubbles coming from around my fuel filter
When the proper fuel pump is mounted on the block you do not need a pulse hose.- !!----No telling what what folks do these days.--Without pictures I can't help on these issues of so,so work.
