Xtyfighterx
Thread starter- Joined
- Oct 2, 2016
- 8
Hello bought my first boat two days ago. Put new mixed gas in got it running took it to the lake and it surges on high idle. I messed with the low idle pin nothing would work. Took it back home and did the following
Clean the carb checked all gaskets used pressurized air to clean the ports
Compression check 100 on both cylinders
New plugs
Check my spark arcing at 7/16
Used a meter checking my coil packs
Swapped plug wires
Check my fuel pump diaphragm
New main fuel line and fuel tank
Seafoam in the fuel.
Also put some fuel in the top cylinder that's dead and removed the bottom plug wire to the bottom cylinder it started and ran for a few mins
It Starts first pull and idles great runs ok until high idle. Top cylinder is dead. Runs with out the plug wire on.
Any help please
New plugs
Swapped plug wires
Any help please
