stpauli914
- Nov 16, 2009
- 8
Hello everyone! I just discovered this forum and WOW!! What a great wealth of information. After reading through a bunch of threads that were similar to my problem, I figured I would register and post as many details about my problem as possible.
Motor is a 1985 Johnson 150 VRO disconnected running on 50-1 ratio. Compression is 105-115 in all 6 cylinders. Carbs were rebuilt 20 hrs ago, new water pump kit and gear oil, new NGK plugs. Boat is an 18' Hydra sport CC.
My problem comes and goes, it is a surging and erratic running at any throttle range. I will be running fine and then the motor will drop rpm and run barely on plane then it will surge into more rpm where it should be. Then it goes right back to lower rpm. Doesn't sound like its running smooth either. Even at idle(in gear) it is rough and jolty. I replaced the water seperator with a new one(whole thing, not just filter) and it ran without issue for a few outings. Now it is back to the same problem as before?? I have tried pumping the primer ball while having the problem with no change. Primer bulb never really gets that firm though and I have tried 3 different brand new bulbs of 3 different brands so I think the bulb is ruled out
I did notice a spark arcing from the top left cylinder coil. It was arcing from the orange wire lead to the boot that connects to the coil and leads to the spark plug boot. I have since remedied the problem with a new rubber boot around the orange wire end.
Any help is MUCH appreciated. And of course I'm sure I missed something so ask away.....
