sred137
Thread starter- Joined
- Nov 24, 2009
- 62
The motor starts fine.Then when getting up on plane sputters for a second then seems to clean itself out and run smooth as can be.At idle it seems to be loading up and begin to stall if I don't put it in neutral and rev it up.When I rev it up it smokes like crazy.I did some searching and found that the line that is feeding the carbs was cracked and changed it,but have not ran it since.When I took off the plastic cover that covers up the carbs. it had about a cup of unused fuel.The crack that was in the fuel line was to the top of the VRO pump and was minor.Enough to possibly suck air but not enough to dump that much fuel.
After running the motor and inspecting the plugs.They are equally fowled.I will be running the motor this weekend to see in the change in the fuel line fixed my problem,but any other suggestions are very welcome.
