Good afternoon folks! first i'd like to introduce myself. i bought a 100 hp motor for my boat after the 50 hp blew up. i'm trying to get my boat water ready so i can enjoy some catfishing! so here goes my laundry list of questions/issues (apologies in advance for my scattered thoughts going into text):
1) is there an easy/cheap diy method for rigging up tilt/trim controls? the tilt/trim controls were not included and i'm really not trying to drop a lot of $$$ into this setup if possible. is it possible to just rig up a switch for each motion? with this old boat, i'm all about function over looks. i only intend to use it to get on the river and find the catfishing spots.
2) i'm having some fueling issues. the fuel line will prime nicely, but it acts like it's not getting fuel. it would start and run as long as i kept priming the line, but now it'll only start up if i turn the knob on the primer solenoid and let fuel run down the front of the carbs. however, while cranking the primer ball pressure drops as if it's taking fuel (yes, the fuel flow is in the right direction lol). the fuel line is brand new as well. i've disassembled the carbs, cleaned them, and put them back together. the only debris or gunk i found in any carbs was the lower carb in the bowl but some carb cleaner seemed to have blasted it all out. i added seafoam according to the dosage on the bottle (6 oz for 3 gallons) before doing all of this, and i'm also running pre-mix fuel. the oil inlet on the vro was broken off, so i sealed it with some marine goop, and let it sit for a day so i wouldnt have air intrusion there. i feel like i've pretty much done every check i can to troubleshoot this issue. i have been going by the boat manual i have that covers this motor. at this point, my only ideas are that there's a vacuum leak to the crank case from the vro, or the vro is toast. i took the vro apart and the diaphragms look to be in good shape. once i sealed it back up i sucked on the vacuum port and didnt hear any leaking. the only idea i had as far as testing it was unhooking the output line and cranking but i'm not sure if that's the right answer as far as testing the vro. either way, i didnt see any fuel coming out of it. when i get off work, i plan on taking the carbs off again, but this time disassembling them and dropping them in either seafoam or a solvent for a few days and then blasting them with some air. i may also replace all of the fuel/vacuum lines inside the engine bay.
if anyone could give me some pointers it would be greatly appreciated! thanks in advance!
