1985 Johnson 100hp v4 model #J100WMLCOC questions
mikeypb86
Good afternoon folks! first i'd like to introduce myself. i bought a 100 hp motor for my boat after the 50 hp blew up. i'm trying to get my boat water ready so i can enjoy some catfishing! so here goes my laundry list of questions/issues (apologies in advance for my scattered thoughts going into text):
1) is there an easy/cheap diy method for rigging up tilt/trim controls? the tilt/trim controls were not included and i'm really not trying to drop a lot of $$$ into this setup if possible. is it possible to just rig up a switch for each motion? with this old boat, i'm all about function over looks. i only intend to use it to get on the river and find the catfishing spots.
2) i'm having some fueling issues. the fuel line will prime nicely, but it acts like it's not getting fuel. it would start and run as long as i kept priming the line, but now it'll only start up if i turn the knob on the primer solenoid and let fuel run down the front of the carbs. however, while cranking the primer ball pressure drops as if it's taking fuel (yes, the fuel flow is in the right direction lol). the fuel line is brand new as well. i've disassembled the carbs, cleaned them, and put them back together. the only debris or gunk i found in any carbs was the lower carb in the bowl but some carb cleaner seemed to have blasted it all out. i added seafoam according to the dosage on the bottle (6 oz for 3 gallons) before doing all of this, and i'm also running pre-mix fuel. the oil inlet on the vro was broken off, so i sealed it with some marine goop, and let it sit for a day so i wouldnt have air intrusion there. i feel like i've pretty much done every check i can to troubleshoot this issue. i have been going by the boat manual i have that covers this motor. at this point, my only ideas are that there's a vacuum leak to the crank case from the vro, or the vro is toast. i took the vro apart and the diaphragms look to be in good shape. once i sealed it back up i sucked on the vacuum port and didnt hear any leaking. the only idea i had as far as testing it was unhooking the output line and cranking but i'm not sure if that's the right answer as far as testing the vro. either way, i didnt see any fuel coming out of it. when i get off work, i plan on taking the carbs off again, but this time disassembling them and dropping them in either seafoam or a solvent for a few days and then blasting them with some air. i may also replace all of the fuel/vacuum lines inside the engine bay.
if anyone could give me some pointers it would be greatly appreciated! thanks in advance!
Bosunsmate
Its normal for the primer ball pressure to drop a bit while cranking. Does the primer bulb go hard while you prime with the engine off? And does it hold firm with engine off?
Also how are you operating the choke, whats your key procedure at start up to operate the choke, this is very important.
Ive no idea about the tilt switch
mikeypb86
the primer bulb goes hard when i prime it with the engine off and it does hold firm. there doesnt seem to be anything specifically for a choke. since i'm still troubleshooting i have the throttle cable disconnected and i just crack the throttle plates open a tiny bit. then i primed it a little with the solenoid, shut the solenoid back off and cranked it up. it would run for about 20 seconds then run out of fuel in the carbs. i would then repeat the process and pump the bulb while it ran. this worked for about 5 minutes then the motor just fell on it's face and i couldnt get it to start up again. plugs got wet fouled, probably from using the primer solenoid too much. i tried taking them out, hitting them with carb cleaner, drying them, putting them back in and trying again. when i get a chance to get back out there i'm gonna see if it'll start up again since it may have been flooded. i'm hoping that the sea foam just broke some gunk loose and clogged the jets. that's an easy fix. oh, i also set the gap at .040, which is what the manual called for. they were originally gapped a lot closer. i did this the other day but there was no difference.
Bosunsmate
Ok time to spell out the way these things work. The choke is that solenoid it works by squirting a bit of motor into the engine when you PRESS IN THE KEY.
Now to start these motors you must give it a bit of start up lever and have the bulb firmly primed and then as you turn the key to start you then press in the key.
What you a doing there trying to micromanage the engine will just be overloading it. Not even a guy with three brains and three sets of arms could move everything in sync with what the engine needs.
So what i suggest you do is hook the engine back up to the controls, use the choke as described and when the motor starts to die do whats called bumping the choke which is pushing the key in for a second which shoots in more fuel and stops it stalling. You don this until the motor warms up.
Now you said the plugs are wet so if this above doesnt fix your issue you might want to check your thermostats are closed properly.
mikeypb86
hmm, i hope the fact i have the controls from a johnson 50hp on this motor doesn't cause an issue. it has a toggle switch for choke, which worked on the 50 hp i had on it, but doesnt do anything on the 100 hp it has now. the key on this doesnt push in. it's a johnson powershift 2. now, how would i check the thermostat on this motor and where would it be located? i'm not seeing the correlation of thermostats and wet fouled plugs :confused: unless cold cylinders is preventing a proper fuel burn.. i was also trying to use the warm up lever that's under the key when i did have the throttle hooked up and there was no difference.
mikeypb86
Also you could rig up a gravity feed fuel tank to check that the fuel pump isnt faulty
great idea! i've already discovered that my pick up line inside my fuel tank is leaking air in. since i guess it's some sort of universal tank, and i had to cut the quick connect off to clamp onto it anyways, i stuck the hose directly into the tank. prior to this i wasnt getting a hard bulb haha
Bosunsmate
how would i check the thermostat on this motor and where would it be located? i'm not seeing the correlation of thermostats and wet fouled plugs :confused: unless cold cylinders is preventing a proper fuel burn.. .
Cold cylinders yes and wet plugs is what i was pointing at. Thermostats are in the part out the back where the two hoses go
Bosunsmate
Well check that that is moving the throttle linkages properly because it should be making a difference. Choke switch is fine if key is not the std one
mikeypb86
the warm up lever does have an effect on the throttle linkages, opening the plates just a little. as far as the choke switch, i dont think it has a function on this motor. on my old motor it would activate the choke solenoid. when i try to crank it up again during more troubleshooting i'll try holding the choke switch and see if it makes any difference. another news update. as i'm typing this, i double check to verify my plugs. i could have swore my clymer manual said .040. the johnson/evinrude website says .030. i gapped them at .040 before i saw the website, thinking they were gapped wrong, now i will have to gap them back to .030 (oops!). another thing i'm gonna do is replace the battery. it's old, and doesnt hold the best charge. its a long shot, but as far as making sure i get enough of the right spark, it'll be good for peace of mind. i would imagine slower cranking would mean less airflow into the carbs and slower pulse to the vro, which would mean less or no fuel output during cranking? either way, it's getting a new battery. i'm thinking about just putting my 55 gallon drum in the boat and putting the tank on it for a gravity/syphon feed to test the vro. also i'm replacing all the vacuum/fuel lines under the cover to eliminate air intrusion possibilities. if none of this works, then the carbs will come off again, get soaked in seafoam, air blasted, and try again.
it can be a headache for me to diagnose these issues, but overall i enjoy tinkering with and learning about it. this is my first time ever digging into something with a carburetor and first time ever messing with anything marine haha. i should have kept my blown 50hp and took it apart, but i sold the whole thing for the lower unit, which a guy wanted. i have a buddy who will show me how to rig up the switches for tilt/trim. lastly, before it goes in the water i'll have to drill, install, and seal the lower engine mount bolts. i only put the top ones in so i could get the boat back to my house from the seller's house.
Bosunsmate
when you hit the choke switch you should hear the solenoid click, engine must be on for this but not started
emdsapmgr
You've got yourself a strange animal, in that commercial engine. Some differences between your engine and the normal consumer models. It's got lower compression heads, so that it will run on low octane fuels found outside of the U.S. The gearcase is not standard. It may be a larger gearcase and uses non-standard gearsets. So you will have to look around to find an optimal prop for it. The ignition timing may be slightly different and it may have different running characteristics. Hopefully, you are working from a genuine factory service manual for this exact engine. This is on top of your current concerns. Having said that, the engine is basically solid and should run well for you, once you get through your teething problems.
mikeypb86
yes i do hear the solenoid click when i hit the choke and it does prime. i replaced all the fuel lines, rebuilt the carbs, and in the process, discovered that the old plastic fuel line had a crack where the 3/16 line to the primer solenoid comes off. replaced it with some brass fittings. when i went back at it today, the primer ball would pump up and get hard. eventually it coughed to life and ran for about a minute then died. no fuel in the lines. after that, the primer ball wouldn't get hard and the lower carb would spew fuel out of what i'm assuming is an overflow. and of course i couldnt get it to start up again.
mikeypb86
also in the process of replacing all the lines, i got actual hose clamps, not zip ties like the previous owner did. i'm also wondering if the new floats needed to be adjusted. i didnt check them thinking that they should be factory preset to the right specs. i also notice there's always a little air in the fuel filter housing. i'm wondering if i should turn it on it's side, since the outlet comes out the top of it. i do not have an exact manual for this exact motor. i have a clymer manual that covers all johnson/evinrude up to 85.
Bosunsmate
yes you need to check the float, fuel spilling out is a symptom of an incorrect float. I check mine by tunring them upside down and checking i cant blow into the intake.
mikeypb86
I'll do that when I get home today. That wouldn't cause it to run out of fuel would it? I've also heard that you have to keep your tank sealed in order for it to work properly. Doesn't make sense to me that creating a vacuum in the tank would help it draw fuel lol. Just thought I'd ask a 3rd opinion.
