I have a 1985 force 85Hp that has some troubles. The engine is miss-firing when idling as well as bogging. It will start and idle, but when I open the throttle it wants to die. I have found that opening the throttle and then tapping the electric choke will cause the engine to get up to proper RPM's. So I replaced the fuel pump with no improvement in performance. I also replaced the plugs with UL18V's, no improvement. Today the engine ran better than ever for a short time, when I opened the throttle the engine just too off. Also my rpms made there way to 5K, until today I have only seen the high 3K range. Later however the engine began acting as before, lower rpm's and bogging except while using the choke on and off. Lastly, the carbs were rebuilt last year. I have read that the fuel bulb should go flat when running, is this true? Help...
