FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Remove the plugs and try to turn it over.If it turns over do a compression test.Will it trurn over by hand?
Then pull the drain plug and check for metal shavings in the oil.
More info on what you can and can't do.J
