1985 evinrude 90 hp on 14 ft boat
82rude
For 1966 theres only a few glass starcrafts listed in the 14 foot range. Depending on the model 40 hp to 60 hp max.I had a 14 foot glasser a few years ago that I slapped a 90 rude on but it wouldn't go very fast also.Looking closely one day I noticed the transom was flexing severely needless to say that 90 came off pronto as I valued or value my life more than speed.Its your boat and your life but with that 90 running properly that combo may be very dangerous.Not preaching to you just saying be very carefull.This is also assuming the title is correct and it is indeed a 14 footer.Max hp for omc that year was 100 hp I believe.
Chris1956
Honorary Supreme Mariner
Even planning hulls are designed for a certain speed. Not all of them will go faster efficiently. So even if you load them with power, the performance increase may be minimal. I am not suggesting this is the issue in this case, but it is a possibility. Flat bottom or low Vees tend to go faster as power and trim increases. Straight Vee hulls tend to rise up in the water as speed increases, but don't respond well to bow trim. Not sure what Tri-hulls do....
Check the hull for straightness. A hook in the hull will drive the bow into the water, killing speed.
Make sure the boat is not plowing water at higher power settings, due to it's trim. The wake should originate near the transom of the boat at higher throttle settings.
