1985 evinrude 90 hp on 14 ft boat
Trevorburdette
I recently purchased a 14 ft boat with a 90 hp evinrude vro with the vro disabled
I bought this boat with the thought of it being scary fast and i took it out and it only went about 30 mph Does this seem right?
its not a very big or heavy boat and the motor didn't idle very well but i thought it was just because it was an old 2 stroke but it idled worse than any other motor I've ever had. I will try to add pictures but its not letting me at this point
jbcurt00
a 1985 evinrude isn't really an old 2stroke
What kind of 14ft boat?
a 90hp on a 14ftr sounds overpowered
If you need help w/ a poorly running outboard, it'd be helpful for you to post the model number
Trevorburdette
its a e90tlc0s and the title says its a 1966 starcraft but it looks relatively similar to a 70s ranger tri hull bass boat
hunter200524
do a leakdown test, the rings are most likely blown out of it. If not check spark, if both are good pull the drain screws on the carbs and look to see if they are green.
robgunther87
It could be your prop as well. You might have a power prop on your boat, which will give it more lower end torque (like pulling a wakeboarder out of the water) but however doesn't have very high end speed at WOT, vs a speed prop has little torque in the lower end but will allow you to go faster at WOT.
1983 ercoa 21'
I'd hook up a tach so you know what is going on.
do you know what pitch of prop your running?
sutor623
The prop wouldnt cause it to idle bad.
I don't think he was saying it would hurt idle, just hurt top speed (which I believe is the OP's primary concern). And its not like you are giving gems of information either. Didn't you just say, "Most likely the rings are blown out of it." And what the heck were you trying to say when you said to pull the drain screws to see if they are green??? Also, a more reliable test for a 2 stroke outboard is a compression test. And yes, we all agree compression test is where to start when diagnosing an issue like this.
Believe me if we all just decided that our outboards idled poorly because they had blown rings, there would be a lot of good powerheads in the scrapyard. I doubt that motor would push ANY boat 30MPH if the rings were shot. I see that you have just joined the forum. Its not my job to criticize others on here, but maybe you should do a little more research before giving advice on here.
interalian
30mph by what? GPS? Or some old gauge on the dash (notoriously inaccurate).
That motor on a 14' boat should push 45+mph with the right prop
hunter200524
I'm sorry I work on these motors every day. I have rebuilt many of them either due to rings being blown out or the vro pump failing. If you don't know what I mean by the carbs being green you shouldn't be replying. Also a compression test is NOT an accurate way of determining if your cylinders are good. A leak down is more reliable. Idk how many motors I have worked on that have been looked at by other shops to only have done a compression test and say the motor is ok. Then the customer still have problems with it, brings it to us and it fails a leakdown, and I put my borescope in the cylinder to find rings blown out of it (very, very common problem). And me saying the rings are out of it is just using the information I have ( bad idle, only 30mph on a 14ft boat). Also i have replaced alot, ill say it again alot, of power packs on these motors, hence why i said check spark. If the motor isnt idling good, its not going to magically fix itself off idle. Make sure its running on all 4 cylinders. have a good day sir. I'd like to add just this last year I rebuilt 7 85 to 115 4cyl 2 stroke johnsons. And have probably repaired over 30 in the last year. If this really is a 14ft boat it should do 50 plus mph
oldboat1
'85 90 ain't an "old two stroke" in my world either. But it's a heavy bugger, and I think jbcurt's suggestion is that there is an issue of weight to power ratios -- that the 90 might be a tad too much motor (maybe as in damned dangerous -- YouTube stuff). I would like to know more about the hull, as I'm not sure it's really like a '70s Ranger bass boat -- latter is a beamy, beefy rascal as I recall, and deeper than it looks at first glance. The mental pic I have of the Starcraft, on the other hand, is like the Chrysler precursors to bass boats ('60s or so). If I have the right idea, it's a fairly narrow hull, and pretty shallow -- tri-hull style, which would probably lend some stability, but for that 90?
so would like to hear what the OP has in the way of compression tests (knowing they are not the end-all), and spark tests, then some fuel and carburetor discussion -- maybe some potential for a cylinder dropping out at high rpms, some ignition issues.... But I would also like to hear something (and see something, maybe) about that hull -- maybe some technical advice on ratios. What is the factory hp rating for that '66 hull?
:couch2:
F_R
Honorary Supreme Mariner
If you think it should be scary fast, just the thought of it is scary to me. Aside from that, obviously it is planing out if it is going 30. So why isn't it going faster? Since it idles poorly, lets assume the motor is sick, and not a prop issue, etc. Yeah, I know, never assume. I'm betting it isn't running on all 4 cylinders. That could be a compression problem, or an ignition problem, or one of the carburetors is dirty or not getting gas from the tank. It is impossible for anybody to sit at a computer and diagnose which it is, without more information. A simple compression test, spark test, and yes look for crud on the carb drain plugs, are some basic tests you should be doing.
Shoot, my 35hp goes more than 30 on my 14 footer.​
Chinewalker
Although a compression test doesn't always tell the story, it can certainly set the stage. If you're getting 120 on three cylinders and 50 on the fourth, there's a good chance there's something wrong.
hunter200524
Well yes a compression test will tell you if something has completely gone wrong. But it won't exactly tell you if the motor is good. If you have 3 cylinders at 120 and one at 50 something is obviously wrong. But if all 4 are at 120 it doesn't mean that nothing is wrong. And that's why with these pertucular motors I recommend at least looking in the cylinder with a bore scope. Also if a cylinder is that bad you should be able to hear the sound difference when cranking it over.
Trevorburdette
I did a comp test a few days ago and all 4 were at 130 give or take 2lbs and it almost sounds like its misfiring when I'm at full throttle it makes a deep running sound when I'm going fast but it makes a much higher pitch sound when it sounds like its misfiring almost like I've lost spark so ill check that and i figured the carbs were pretty dirty
1983 ercoa 21'
You can do a cylinder drop test to see which cylinder is missing.
you can test spark by seeing if the spark will jump a 7/16 gap
oldboat1
more like a description of over revving, rather than misfiring. that could be cavitation or a slipping hub -- performance issues on that hull. You connect a higher pitched sound with misfiring -- think I'm not getting that. (btw -- got a pic of that rig? hp rating shown on the hull plate?)
