1985 evinrude 6hp fisherman
harpe3
how hard is it to change the impeller on 1985 6hp evinrude fisherman ? also does it discharge below the water line, i dont see a stream of water ?
sutor623
Re: 1985 evinrude 6hp fisherman
Its easy. Just gotta be easy and patient for your first time. My 4hp blows steam out of the exhaust (upper midsection) and does not have a telltale. Not sure about yours tho.
raczekp1
if its realy 86'
and standard 15" shaft,
then one bolt from the top of lower unit
and 2 bolts under cavitation plate should be out
pull down lower unit and you should takie apart lower unit fro mid section,
take out lower unit, unscreawv 4 bolt from water pump housing and pull up water pump housing,
