1985 Evinrude 60hp idle issues
Keitro
1985 Evinrude 60hp (E60TLC0D)
Good Afternoon,
I?m having an issue with poor idle characteristic?s she will idle rough out of the ramps (but not stall) after running for some time when I try to idle back it will stall (like a flooding condition) wait 30 minutes and it fine again
When adjusting the cam follower pickup timing the service manual shows the spec should be 2-4 BTDC the best I can get mine is 8-9 BTDC without not stalling at idle (I did have to install a longer screw to adjust idle so it would idle correctly)cam advanced
Max spark advance is spot on at 21
Things replaced for the ignition system:
Charge coil, stator, sensor, power pack, and both coils
Carb?s
Things that I did notice is drops of fuel/mix spitting out of carbs
Did a rebuild on the carbs a year ago but did not remove the idle air bleed orifice (scared me did not have the service manual at the time) any tips will be greatly appreciated
I?ve been looking at some of the carb rebuild FAQ?s here and going over some of the stuff I missed the questions I have are to soak the carb in a mix or not. I soaked them just for an hour the first time I rebuilt them but do most people soak them overnight?
Should I pull the intake and clean/Inspect the leaf plates?
This is a project boat that was gifted to me from my dad (that I and my brother tried to fix as kids. Not good...Lol) but I want to keep it in the family and has been a great learning tool?she is out on the water every week but thank god for a trolling motor
Thanks again,
Keith
Honorary Supreme Mariner
All the work done so far is good.---But the trouble shooting on an outboard starts with a compression test.---Report your numbers.
Bosunsmate
i dont remove those small ones either, i just get like a can of wd40 or preferably carb cleaner and put the the little white pipe that comes with the can up hard against the orifice and blow. While doing that i check that the fluid is hosing out some other outlet in the carb wherever that may be. If it isnt hosing out at a good rate of knots then there is a blockage, often doing that blowing with the fluid will free it loose otherwise a soft bit of copper wire down it does the trick normally.
Yes compression check and also check your flywheel key is ok.
You can do that by moving your number 1 piston to tdc and checking flywheel is at 0
clemsonfor
Is your float set correctly ? Seems if you see too much fuel your flooding or loading up at idle.
Keitro
Compression is 120/120
The key on the flywheel looks good I will pull a plug and check
I have some carb. rebuild kits on the way I'll spend some time on them this time
Thanks again
Keitro
To soak,or not to soak
Carbs that is
The shop manual says just to use carb cleaner...I'm prob thinking to much into this but I'm waiting on parts
Thanks again
My compression tester would show 140 + on those 2 cylinder motors.----Did you remove the flywheel to check the key ?
Bosunsmate
Ive one of those two cylinder 60hps and compression is 118/110 and it runs great so i wouldnt worry too much about your compression numbers at the moment as they seem good to me.
You could do a drop test to see if both cylinders a taking the load evenly or if not you could trace it down to one of the cylinders
Bosunsmate
No Title
If this is the two cylinder model you also have to relocate the telltale outlet to the top of the crankcase. You can see in the photo where ive put mine just under the lifting eye. Failure to do so can mean airbubbles get trapped in there meaning that a hot spot will develop especially at lower rpm
Keitro
Pulled flywheel yesterday key looks good....received my parts today...I'll keep you informed
Thanks again,
Keitro
No Title
Well I think I found a problem!!!! Yep....I'll have to give my carb rebuild guy a call tonight (my Dad)
oldboat1
Carbs that is
Thanks again
big believer in disassembly and soaking, particularly for varnish -- soft wire or mono for nooks and crannies, followed by carb spray.
