1985 Evinrude 60hp (E60TLC0D)
Good Afternoon,
I?m having an issue with poor idle characteristic?s she will idle rough out of the ramps (but not stall) after running for some time when I try to idle back it will stall (like a flooding condition) wait 30 minutes and it fine again
When adjusting the cam follower pickup timing the service manual shows the spec should be 2-4 BTDC the best I can get mine is 8-9 BTDC without not stalling at idle (I did have to install a longer screw to adjust idle so it would idle correctly)cam advanced
Max spark advance is spot on at 21
Things replaced for the ignition system:
Charge coil, stator, sensor, power pack, and both coils
Carb?s
Things that I did notice is drops of fuel/mix spitting out of carbs
Did a rebuild on the carbs a year ago but did not remove the idle air bleed orifice (scared me did not have the service manual at the time) any tips will be greatly appreciated
I?ve been looking at some of the carb rebuild FAQ?s here and going over some of the stuff I missed the questions I have are to soak the carb in a mix or not. I soaked them just for an hour the first time I rebuilt them but do most people soak them overnight?
Should I pull the intake and clean/Inspect the leaf plates?
This is a project boat that was gifted to me from my dad (that I and my brother tried to fix as kids. Not good...Lol) but I want to keep it in the family and has been a great learning tool?she is out on the water every week but thank god for a trolling motor
Thanks again,
Keith
Good Afternoon,
Carb?s
Thanks again,
Keith
