1985 DT65 Suzuki fast idle issue
Pikebend
Engine runs fine. At start up engine goes into a high idle. Hard to shift in and out of gear with excess pressure. Won't idle down. Carbs are cleaned and rebuilt and adjusted. No excess air leaks. Idle speed adjustment replaced with no help. Switches on second carb in correct adjustment. Just bringing back from an outboard mechanic that gave up. Need help.
thanks
Pikebend
99yam40
Re: 1985 DT65 Suzuki fast idle issue
check to see if idle timing is in spec
Too far advanced will cause high idle RPM
