nrasnake
- Aug 13, 2012
- 62
Re: 1985 Conroy X-19 I/O Transom Restoration
Back to the fiberglass! The new manifold and elbow on their way and all the outdrive and gimbal parts are on the shelf.
I've been thinking about how I'm going to flatten the hull around the transom since I didn't use enough 2x4 clamps and the resin kicked much faster than I expected last fall.
This what it looks like:
It is within spec (<1/16") from port to starboard (horizontal) and well out of spec (0.1" max) from top to bottom (vertical). There is a high spot at both upper transom plate through holes. The overall thickness varies of course, but is between 2.17"-2.29". So, it is too thick (>2.25") at the high spots.
My plan is to shoot for a final thickness of 2.21" by grinding down the high spots (approximately -0.08") and filling the low spots with one layer of CSM (+0.03"). This should put the overall thickness to within 2.20"-2.21" and allow for a final layer of gelcoat. I can take a little bit more off of the inside transom surface to stay below 2.25" thickness if needed in the end. Obviously, I won't be able to control everything to 0.01", but this is for planning purposes.
Do you guys think this work?
1. Take the gelcoat off (down to the hull fiberglass) inside the blue oval shown (feather at the line).
2. Grind down the hull fiberglass at the high spots by the amounts shown in the orange and red ovals (feather at the line).
3. Put a patch of CSM in the green ovals.
4. Peanut butter around the edges of the CSM patches to feather the edges in.
5. Grind the edges of the CSM/PeanutButter smooth.
6. Block sand the entire surface inside the blue oval to reach the final flatness desired.
7. Gelcoat the entire surface inside the blue oval and feather onto existing gelcoat.
8. Block sand the entire transom surface.
My biggest concerns are with adding the CSM/PeanutButter as a filler, but I don't know what else would work and still be structurally sound. I've also never used gelcoat, so I'm not sure what to expect. Any suggestions or ideas would be much appreciated. I think it's all down hill from here if I can get this straightened out.
Thanks!!!
Thanks!!!
