1985 90 mercury Idle problem
rjsizemore
I have a 90 mercury on a 15.8 ft fiberglass boat. Just had a stator an trigger replaced also power packs. When starting have to choke it with the throttle down Will not Idle at all. Sometimes it will idle for a few seconds but when you put into gear it quites. Its also very slow to plan has good compresion on all 6 cylinders rangeing 125 to 130 looking for some advice
KCLOST
Re: 1985 90 mercury Idle problem
Who replaced all the ignition components?
KCLOST
If they determined that the stator and triggers were the cause of your problems, and it didn't fix it I would demand that you get your money back...<br />I assume that they did the sync and timing also?
rjsizemore
I tooked the carbs off today took each one apart cleaned them. Started it back up did not help any I noticed when it was running that the bulb was trying to squeeze together what would cause this can anyone help
rjsizemore
I would greatly appreciate any advice at all
Mettaree
Sounds like you have a lack of an active vent on your gas tank. Try running on a portable tank.<br />Also tank side check valve in bulb maybe causing<br />problem. <br /> :)
rjsizemore
If the timing was off on my motor what would be the symtoms?
rjsizemore
well I cleaned my carbs again it will sit and idle with the muffs on but will not start unless you have the throttle down. I let it idle for 2 or 3 minutes and still would not start unless the throttle was down.
