1985 3.5 help
Bradb511
I got this motor a week ago. I cleaned the carb and replaced the impeller. It will run for about three seconds every time i pull it. Which screw is the idle screw on the carb and what is the other one for? HOw many times should i back both of them out just so it will run, then ill mess with them to get it runnin better.
thanks
25_hp_xd_man
Re: 1985 3.5 help
The other is your air mixture screw. The way to adjust it is to screw it all the way in and then back it out 4 turns. Start the motor and fine tune adjust from there.
Bradb511
Re: 1985 3.5 help
Does anyone know if i can get an online manual for this thing?
