My boat had not run in awhile, as in about a year. I cleaned out the carb and installed a new kit, spotless. After I reinstalled the carb and went to crank it up, it would only run a few seconds and then stall. After checking the gas tank and gas line (all clean) I decided to take off the carburetor and check it out. It was clogged up with a chalky greenish white substance. I cleaned it out, reinstalled it, and the same thing happened again -- run for a few seconds and then stop. I don't know where this junk could be coming from and would appreciate any insight you can offer. Thanks much.
