1985 28hp Johnston Junk in Carburetor
Redbelly4
My boat had not run in awhile, as in about a year. I cleaned out the carb and installed a new kit, spotless. After I reinstalled the carb and went to crank it up, it would only run a few seconds and then stall. After checking the gas tank and gas line (all clean) I decided to take off the carburetor and check it out. It was clogged up with a chalky greenish white substance. I cleaned it out, reinstalled it, and the same thing happened again -- run for a few seconds and then stop. I don't know where this junk could be coming from and would appreciate any insight you can offer. Thanks much.
oldboat1
Maybe an '86(?) Stuff coming from somewhere. Think I would make sure I had fresh fuel in a clean tank, unhook the hose at the carb and pump fuel into a container using the primer bulb. See if it's clear before trying to run.
Redbelly4
Could it be that the "junk" in the carburetor is coming from the fuel pump? I don't know where else it could be coming from.
jakedaawg
Yep. Or the many fuel lines, or the fuel filter, or the fuel bulb. At this point, the solution is to repla e the lines, all the lines. Also disassemble and clean the fuel pump taking care to note how you took it apart.
oldboat1
You might try a variation of the test mentioned earlier -- With the line to the carb removed, pump fuel into a container (glass jar is best) by cranking the engine. If the stuff is coming by way of the pump, you would see it in the container.
Any sense of what the stuff is? Maybe corrosion that was loosened up somewhere. (Think we're assuming you completely disassembled the carb and soaked, poked and sprayed.)
Redbelly4
Yeah, the junk in the carburetor looks like some type of corrosion. These are all good suggestions, and I really appreciate it. I am going to give them a try . Thanks.
Redbelly4
And, yes, I did completely disassemble the carburetor, soaked it in carburetor cleaner, and blow out all of the orifices with canned air. There is a chance I missed something but I don't know what it would be.
oldboat1
not for lack of trying, eh?
pretty much out of ideas here. maybe a float coating that a PO unsuccessfully tried.
