I have a 1985 25 hp johnson (J25RLCOS). I've put in a new head gasket, water cover gasket, thermostat, impeller, and two new ignition coils. the thing starts in one or two pulls and will stay running til i shut it off. i put on new fuel lines, connectors and changed tank. i can turn throttle wide open when motor is in neutral and it goes fine, same for reverse. as soon as it put the motor in forward, i can only open up about 5/8 throttle and engine sounds like it's bogging out out or flooding. i have a repair manual and think i've nailed it down to either the power pack or the stator.
i'm checking to see if anyone else has had similar problems and what the diagnosis was, thanks for your time.
