1985 175hp yamaha 2cycle outboard temperature?
cireg24
Thanks to all that help out throughout this forum..shot the temp radar gun around sparkplugs area and got temperatures readings starboard side around 180 all 3 cylinders. Other side 136_145......how high should temp go sitting in drivewy with flush hose assuming starboard not cooling where do i start does this motor have 2 thrmostats
Water out of pea hole not strongest but decent will change that anyhow but one side is much higher than other...please chime in ty.
N1NE1
Re: 1985 175hp yamaha 2cycle outboard temperature?
I would start with the 2 thermostats and pcv valve
cireg24
Ok check thermostats and they are no good changing those....wheres the pcv valve is that the plastic with a spring towards bottom of engine below coil packs
99yam40
yep, that is it.
Change water pump also
cireg24
I changed 2 thermos The pcv valve and spring was checked out by dealer he said it looked good i put back in . Maybe a mistake. started boat it ran around 180f ran it for a few minutes and shut it off. the water out of peahole was good but cold like that wasnt coming out of circulation maybe thats normal. So im assuming 180-190 is tooo hot. So is it possible the water not circulate through the engine and come out of the hole should i have ran it longer maybe thermostats didnt pop being new they match original ones
