1984 v4 90hp pinion bearing
Chumlee
Here is my idea to pull bearing instead of buying tool.
Taking proper size bearing driver, apply underside of bearing. Put piece of all thread thru center of bearing, and center of driver with flat washer and nut attached below that. Use piece of steel across top of casing with allthread pertruding thru. Apply flat washer and nut to wrench bearing up. Will this work or should I buy the tool?
Let me know if I am dreaming. Thanks, all info is appreciated.
