1984 mercury 75hp 4cyl. wiring problem
Mercs and such
My mercury outboard is not right. It looks like a aftermarket push in to choke/on/off. definatly not OEM. anyways, i have no idea of how to wire this engine correctly but when i bought it, i really didn't check all of its features. When i push the key in, no click. the solenoid could be broken, or its not even hooked up? also there is a blue wire at the end running off that is connected to one of the 6 connecting points on the key start. but it is just hanging around the back of the boat not connected to anything. :confused: When i turn the key to try to turn the motor off, i get nothing. :eek: All i want is for the electric choke to work because taking off a 3 part cowl is very annoying every time to manually choke the motor :mad:
IF SOMEONE CAN HELP ME OUT, THAT WOULD BE GREAT. ALL I NEED IS TO BE ABLE TO CHOKE THE MOTOR FROM THE CAPTAINS SEAT, AND THE MOTOR TO BE ABLE TO BE SHUT OFF FROM THE KEY SYSTEM.
THANKS!!
MERCS AND SUCH :cool:
Faztbullet
Re: 1984 mercury 75hp 4cyl. wiring problem
Here is to diagrams with what wire function is and how to test.:D
