sdowney717
- Jul 16, 2011
- 225
Yes pump orientation does that, can change input rotation to match engine rotation, otherwise you have no oil pressure in the trans and it wont even work, no clutch pressure.The orientation of the pump in the velvet drive changes the rotation of the transmission/output for fwd/rev
The cut of the gears on the distributor/camshaft is how the rotation of the distributor shaft is maintained to be the same for lh and rh rotation engines.
Ford did the same thing on their 335 series engines
Velvet drives with gear reduction units can also reverse output spin from engine spin, or keep it the same direction, it depends on the gear reduction design. My 2.93 to 1, has the same direction, while this 1.88 or 1.91 to 1 does reverse output from input direction. All velvet drives with no gear reduction are all same direction.
And you can not just run a velvet drive all the time in reverse gear as a kluge to fix prop rotation. They have a bushing that will wear out, and the gear ratio is also different (from what I have read)
V Drives, I dont know much about prop direction from engine direction. It is likely reversed, as in input is LH, output is RH etc...
