sdowney717
- Jul 16, 2011
- 155
Beginning to wonder if valves are stuck open.
Engine is portside, so should be standard rotation.
Distributor turns CCW, is that correct?
And what is the firing order? 1-8-4-3-6-5-7-2 ?
What is compression range for GM 350 MCIE 260 Mercruiser?
What is the spark timing?
I pulled wires and took off cap and everything looks ok, the rotor does not come off.
I static timed by putting cyl #1 at 8 degrees BTDC and turned distributer till it fired the spark.
I did all that after it has continually refused to fire.
History of engine is owner badly flooded engine to the point of the oil level rose way high on dipstick when he was trying to start up, and he burned out the starter. That problem was caused by needle valve in quadrajet laying in float chamber. I repaired the carb, no more flooding. Oil changed, and now no fire, no start. Appears to have very good spark. We changed the spark plugs. Other observation is when cranking some gas is thrown up out of the carb from the intake manifold Stuck intake valves??
Pulling spark plugs and they are dry. Beginning to wonder is engine has lost compression due to intake valves stuck open.
Plan to check engine compression next
