1984 johnson "bogging down" Help please
Toxicballsax
HI. I have a 1984 (j70) Johnson .I have replaced spark-plugs ,all fuel lines , recon all 3 carbs ,primer bulb has been replaced ,new tote tanks as well .All 3 cylinders are 150 psi
What happens ,is the engine will start ,idle fine ,then when i begin to "slowly push the hammer down" around the 2000 rpm mark the motor will loose all power (like it bogs down) the revs will drop ,then it will stall. If I throttle all the way down ,there will be a slight lull around the 2000 mark ,then bursts into life .
Now this is where it drives me up the wall...As this only seems to happen once the motor has been restarted after usually around 30 min or more (coincidence???) .
If i start ,then stop,then start again straight away ,it seems to be fine .
I can idle ,both in and out of the water and rev it right up ,and no problem .This fault only seems to rear its ugly head when its under load .
Like most boaties ,over spending on their "pride and joy" this is driving me insane .
Please any suggestions ????!!
Huge thanks in advance :)
Haffiman
Re: 1984 johnson "bogging down" Help please
You probably have one carb with a main-jet problem. Remove the cover, have a helper spray fuel-mix into the carb throats when accelerating, one carb at the time, and you will probably find the one giving you trouble.
SparkieBoat
you also need to do a link and sync. and check timing
patrick4266
Recon all 3 carbs? Doe's that mean you rebuilt them with kits? Anyway, do the link and sync and do it right.
Toxicballsax
Thanks for the replies ,Yes the carbs had all new kits .
Sorry but what do you mean by link and sync ?
SparkieBoat
you need a manual..you can search this forum for link and sync
nwcove
just curious, but when you rebuilt the carbs did you pull the welch plugs and physically clean the high and low speed passages?
had the same problem and all mine was i was getting a vacuum on my gas tank. i know have to leave the gas cap almost alll the way off
