GrandPrix74
Thread starter- Joined
- Jan 12, 2014
- 12
Hello All,
Been trying to get my 1984 Johnson 35 HP - J35ELCRR - back in shape. While inspecting and cleaning the carb I removed the low speed needle valve for cleaning. It was about 10 turns out. After I was done with basic carb cleaning I tilted the motor and let all the carb clearner and gas come out the carb. Reinstalled needle valve and come out about 1.5 turns. Started the motor and it fired up quickly, but at idle it skips, misses, spits. At high rpms the motor runs fairly well. Shortly after running for a while I started having trouble starting and keeping the motor running. The low speed needle valve was vibrating and backing it self out. Did some research and realized the needle should go in a retainer. Unless its stuck deep inside I'm missing the retainer. My question is can this missing retainer cause the air/fuel mixture to get out of whack even when its screwed in place?
