1984 Johnson 350v wont start
1984ranger
I have a 84' Johnson 350v that I just rebuilt, the starter engages the flywheel but the motor wont turn over and the starter gets hot. I'm guessing this that the starter is bad. what could be the issue?
boobie
Post a model # ?? Could have bad battery or connections. Check them all.
1984ranger
I replaced the battery, starter and solenoid and still nothing. There's really good spark. I don't know it maybe the harness is wiring wrong and the diagram I have is a pain to read. Model number J150STLCRD.
boobie
Did you have the battery load tested ?? Is the battery new ??
emdsapmgr
Yours is an 84. Always possible that the two battery leads are old. As the wires age, a few strands may separate, leaving the rest of them to carry current. When enough of them break, the ones left must carry more load. Possible your battery cables are/have deteriorated to the point that they get hot when carrying cranking loads. I note that your engine also has the huge 35 amp charging system. If any of the terminal ends of the battery leads become loose, the current won't flow properly and that can heat up the battery leads when the engine is running/charging-further weakening the two battery leads.
1984ranger
After replacing the starter and everything the terminals don't get hot, the starter gets warm but I'm sure that's due to the repeated attempts at starting. Yes the battery is brand new and was placed on a charger prior to installation.
jakedaawg
Take the lower off and the plugs out. Can you now spin it by hand?
emdsapmgr
You may need to pull the starter apart. Likely will find a lot of carbonblack inside. Clean that out. As long as the armature is without scratches, the brushes can be replaced. Check them-if they are worn, replace the brushes. Relube the internal starter bushings an reassemble. (you can get the original brushes from any Bombardier dealer.) This is not complicated, nor is it expensive.
jakedaawg
Is it the proper tooth count.on the bendix? Do you have the old one to compare it to? Is the replacement a bargin one from the net?
1984ranger
Same tooth count as the old one and it is not a barging one but it is from the net
jakedaawg
You take the lower off when you are trying to find out if you have an issue. The gear case can go bad and not allow the motor to turn over. Removing it eliminates this.
Yiu then pull the plugs to reduce compression. If you can spin the flywheel by hand clockwise you now know its your starter or solenoid or battery or bendix....
