Yours is an 84. Always possible that the two battery leads are old. As the wires age, a few strands may separate, leaving the rest of them to carry current. When enough of them break, the ones left must carry more load. Possible your battery cables are/have deteriorated to the point that they get hot when carrying cranking loads. I note that your engine also has the huge 35 amp charging system. If any of the terminal ends of the battery leads become loose, the current won't flow properly and that can heat up the battery leads when the engine is running/charging-further weakening the two battery leads.
