1984 evinrude gear oil
Dennischaves
I need to to change the gear oil on my 84 evinrude 70hp
what kind of gear oil should I get and does anyone know the oil capacity?
Lightwin 3
OMC/BRP "Hi Vis".
Replace the fill/drain plug seals also!
Hi-Vis Gearcase Lubricant for Johnson/Evinrude/OMC
Hi-Vis® gear case lubricant is an exceptional heavy duty gearcase oil. It offers high film strength and protection in wet environments in 1989 and earlier V4 and smaller Evinrude® and Johnson® outboards that specify Hi-Vis®.
Features:
  • High Film Strength: Reduces friction and wear, under normal and heavy shock load conditions
  • Thermal Stability: Gear oil life is extended; sludge and gum accumulation are reduced
  • Rust Inhibitor: Prevents the accumulation of rust in wet gear environments
Product Reviews
Honorary Supreme Mariner
Takes about 30 ounces.--------Fill from the bottom till it comes out the vent screw.
Vic.S
Hi-Vis or any other reputable brand of 80W-90 outboard gear oil.
Capacity 25.4 ounces
If the seals are good the old oil should be "clear and bright"
5150abf
"Lower unit oil" is the key, it has additives to deal with water intrusion that regular gear oil doesn't.
Can't over fill, just put it in till it comes out the top hole, put the top plug in then the bottom.
some will drip while you are getting the bottom plug in but not an issue.
Also watch it as it drains for metal shavings, if it is a milky color there is water and you need a seal.
Dennischaves
Will this oil work
I don' see "hi-vis" on the bottle
F_R
Sure, it will work just fine. "Hi-Vis" is an OMC/BRP trademark name.
Vic.S
Will this oil work
Quicksilver is a reputable brand name.
The "high performance" oil in your picture is recommended for higher powered engines,( more than 70HP) rather than the "premium" grade.
