1984 Ebbtide 176SK Repair.
bobkyle2
Re: 1984 Ebbtide 176SK Repair.
So, I'm going to get some more supplys and stuff this weekend. I'm going to use the 28oz PL glue, But i cannot find a caulking gun that will use it. I looked on Home Depots website and seen they have guns that say there for the qaurt size tubes. Will that work?
bobkyle2
The resin i've been buying i guess has wax in it. So i need to sand between each layer, from what i've read and heard. But, i guess you can lay multiple layers as long as you lay it while still wet??
I will be doing all my fiberglassing in one swoop, So i should be good ?? It would suck if i need to let each layer dry and then sand it. But i will if i need too.
I've figured this out.
bobkyle2
Finally got in some more supplys. 5 gallon of resin and 5 yards of 1708. Hopefully going to get a bunch done this weekend.
bobkyle2
Transom
New stringers installed (The stringer on top of the tank was the template.Its just a trash piece we used)
I got some more cut, And alot of sanding and cleaning done. Didn't get pictures of that. Once i started sanding i put my phones and cameras up lol
