Larry Engelbrecht
Thread starter- Joined
- Jun 21, 2012
- 5
Hello all. Friend's Evinrude starts right away, idles with occasional miss, misses a LOT under throttle. Ran great last year, plugs and wires good, carb was cleaned and kitted last year, appears clean from outside. He said problem started this year, added 6 gallons with no change. Squeezed primer bulb at idle and WOT with no change. I hadn't tried using choke while running but did spray brake cleaner into air inlets - engine slowed down. Boat has built-in fuel tank and we do not have separate portable tank, so how would you suggest I try to feed motor fresh gas to see if tank has bad gas...or is this indicative of varnish in the carb? Thanks in advance.
