1983 SRV 225 Dashboard Fuse size question
DJD
Hello, I have A 1983 SeaRay SRV225 Mercruiser260
I need to verify what size fuse they have on the dash Panel for each device ( Water System/Blower/cabin lights etc...) there is a toggle switch
for each switch there is a fuse I have a problems that these fuses are original and seem to be "fused " inside the fuse holder so its ahrd to twirst the top cap and replace the fuse
If you have any recommendations for removing/replacing these fuses it would be appreciated and would you happen to know the correct fuse size
GA_Boater
Push the cap in and twist. Probably counter clockwise.
