1983 omc 260 to mercruiser 260???
chris0061
I"m looking at a old boat and am wondering if there would need to be any transom work to do on it if I switched out the omc that is on it to a Mercruiser drive and engine? Looks like the omc cut out is bigger.
Re: 1983 omc 260 to mercruiser 260???
Ayuh,... Can't see the Tiny picture,...
If it's a Stringer drive,.. Yes, it'll need to be closed in,+ recut...
Cobras use the same cut-out as Mercruiser...
Being an 83, I believe it's a Stringer drive...
chris0061
I think it is a stinger. I'm not very good with fiberglass so I think I'll pass on it. thanks Bondo
chris0061
I just posted a better picture Bond-o
Ayuh,.... It's a Stringer.....
Fiberglass work is actually pretty Easy,...
Especially when you have such a Great Resource as the Restoration forum here at iboats,...
Search up transom replacement,.....;)
zbnutcase
I'm with chris0061, I would pass as its a lot of work. 'nutcase
