1983 Mercury 80 hp
dugrow
My old prop has the # 48-65588-19 on the end, I ordered a Solas Amita
1411-130-19 from iboats, The new one is 1" longer and the blades look larger also. I don't want to put on till I'm sure due to return policies. Iboats say this iscorrect prop. Will the 1" make a differance ????
Re: 1983 Mercury 80 hp
Ayuh,....
Does it bolt on,+ Fit,..??
1", Where,..?? Which way is it 1" Bigger,..??
dugrow
The length front to back is 1" longer It bolted on, with only 1/4 in of threads showing after nut is tight. seemed much heaver and diameter larger Boat ran 5300 rpms with old prop with this one, droped to 4300 wot but seemed to run fine. I just assumed it was a 19 pitch with 19 being last numbers on the part number on old prop. Does anyone have any info on the part number I listed above. THANKS
