1983 mercury 7.5 no top end!!!
jc_vandermeulen
I just bought a boat off of an uncle. it barely got used for the many years that he had it. It likes to flood, but the bigger problem is i cant get any rpms in forward even when im the only one in the boat. Has anyone had the same problem??? can you help?
bob1340
Re: 1983 mercury 7.5 no top end!!!
First thing to check is that both cylinders are firing. I just went through this with an Evinrude. No guts. Ended up the bottom cylinder was not firing due to a bad condenser. New condenser and she runs like a stripe-butted monkey now. You'd think if a cylinder was not firing it'd miss or run rough, not the case. My evinrude ran smooth as silk, but was gutless.
I just fired up my new to me 1969-1970 7.5 Merc. I bought it and a 12' Gamefisher fiberglass boat for $175.00. The motor looked really new under the shell. Had almost zero carbon inside the lower unit. I rebuilt the bottom end and put a new water pump in it. Rebuilt the fuel pump and carb. Parts were about $110.00 for all I did so far. I put it in the tank this morning hooked up the gas tank, sprayed a touch of mix in the carb, set the choke and she fired up on the first pull. Runs like a sewing machine. Now to fix the boat.
