Forceluver
Thread starter- Joined
- Aug 25, 2003
- 36
The motor seems to run great, 150 psi in all cylinders, new fuel pump diaphram and primer bulb. After the motor is warmed up when I come to a stop and proceed to take off it just does nothing, I have to rev it up a bit then put it in forward to go. Kinda like its starving. When It does go, there is a slight sputter in power but takes off.<br /> I'm able to get 40 mph out of it at 5100 rpm's. So I would think the motor is heathy. If anyone has suggestion that will be great. One more thing, does the motor have to be below a certin angle to run, it seems it will not start if I'm pitched to high.
