1983 Johnson GT 150
ShaneBass
I recently replaced both fuel pumps on motor due to top one leaking when primer bulb was pumped. I put the new ones on and when you pump the bulb everything looks fine until you crank the motor and that's when the top fuel pump spits fuel out of a little hole at the back side of pump. Could I have a faulty pump and new to send back to get replaced? I'm not sure why fuel would spit from back of fuel pump, the lower one seems fine. Any ideas??
Joe Reeves
The diaphragm is broken and allowing fuel to flow through it...... Faulty..... return it with an exxplanation.
ShaneBass
Thanks Joe I didn't think it was suppose spit out like that I will box it back up and return.
Fed
Shouldn't that hole be blocked Joe?
If it doesn't spit while pumping the primer bulb probably the spitting is from the pulse hose via the pump.
ShaneBass
0438559 are the fuel pumps I purchased they are identical to the old ones I took off and the old ones have the same small hole in back but never seen or had an issue with them letting fuel spit out. I replaced them both but only the old top one was leaking around gasket on front and I assume letting air be sucked in because I could never get it to run wot like it use to would do. But now that I have installed the new one it leaks out of that small hole in the back and I really see no way how to plug it.
Fed
Do you have the model number of your motor shane, I've been caught out before while researching these fuel pumps.
Fed
BRP is showing two different pumps.
0393648 upper & 0393650 lower
I am unsure of the difference & if it would cause you a problem or not.
ShaneBass
Thanks Fed I will look into sending the others back and getting these other 2.
ShaneBass
Fed when I reference the fuel pumps they seem to both be 438559 as OEM replacements is it possible that the numbers are different for the top and bottom due to the bottom being a kit with a hose and couple zip ties. I don't want to have to buy the expensive kit if in fact they are the same fuel pumps. I would really like to know if there is any difference in the 2 and if in fact I purchased a lemon fuel pump and that's why its spitting fuel out of back side hole. I'm only asking cause I cant seem to find any info stating that the upper is different from the lower fuel pump.
ShaneBass
There should be no fuel spitting from that hole correct unless the pump internally has failed?
Joe Reeves
The hole in back allows air to escape, needed to allow the diaphragm to flex.
However... it should also leak when pumping the fuel primer bulb up... BUT regardless, there should be no fuel leaking out of that hole at all. I know it was mentioned and I neglected it, sorry... my mind was apparently elsewhere. Since it leaks only when the engine is running, I wonder if it is squirting out of the pump or from the engine somehow/somewhere?
ShaneBass
Well after I talked about it not doing it when the primer bulb being pumped it is coming out but only as a trickle but once boat motor fires it becomes more sprattic and coming out faster. The company is going to replace pump and once the new one gets here I will change out and see what happens.
Thanks to all of you for helping with this issue.
Fed
These fuel pumps give me head spins.
Click on the pictures to enlarge them.
http://forums.iboats.com/forum/engi...30803-rebuilding-fuel-pump-1983-70hp-evinrude
I thought the pumps either had a rear pulse hole to get pulses from the crankcase, a side pulse nipple to get pulses from the hose or both rear & front but you block off the unused one.
If it's leaking when you pump the primer bulb it sounds like the diaphragm has a hole in it.
You'd better come back & let us know what you find shane.
BTW, what hole does it leak from, the large one between the mounting screws?
ShaneBass
No Title
Fed if able to see photo of fuel pump there are 2 small holes opposite of where the bolts go through it's the larger of the 2 small holes.
ShaneBass
Hopefully this weekend I will be able to swap them out and let everyone know for sure and maybe I just get a bad fuel pump fingers crossed anyways lol!!
Joe Reeves
That'll do it I feel sure. Getting two bad pumps in a row... the odds on that... nah, not going to happen! :)
I think that someone previously, who couldn't afford a new diaphragm (or is just a cheap-ass), bought the pump, changed the diaphragm,then returned the pump... and you got burdened with the inconvenience.
ShaneBass
Thanks Joe I'm ready to get back out there and sore mouth some Largemouths.
