I recently replaced both fuel pumps on motor due to top one leaking when primer bulb was pumped. I put the new ones on and when you pump the bulb everything looks fine until you crank the motor and that's when the top fuel pump spits fuel out of a little hole at the back side of pump. Could I have a faulty pump and new to send back to get replaced? I'm not sure why fuel would spit from back of fuel pump, the lower one seems fine. Any ideas??
