1983 Johnson 70HP J70ELCTE Slows down a LOT with Load
osito2789
Hello,
I have research this forum for few weeks and couldn't find something for my specific problem. So I will appreciate if someone can help me.
I have a 15.8Ft Glastron T-161 with a 1983 Johnson 70HP J70ELCTE.
Bout it about 2 moths ago.
My Problem is:
On WOT, Motor runs good by my self. and runs okay with me and wife. But whenever I put more people, like 4 people on boat, it slows down really bad. like between 5-10mph. I do not have a speedmeter so im guessing the speed.
it does kinda goes on plane position and Im guessing is because the hydrofoil (stingray xrIII) I put on it, but like I said it goes really slow, and rpm wont go over 2,500rpm, and use a hell more fuel too.
What I have done so far:
- New fuel line (from gas tank to fuel pump)
- New Rectifier
- Run lot of SeaFoam thru the gas tank.
- Clean 3 Carbs.
- Change sparks plugs
- Replace bottom cylinder spark plug wire that was broken.
- Clean Fuel filter attached to fuel pump.
- I have checked for leaks on fuel lines from pump to carbs.
- Upgraded 15pitch aluminum propeller to 17pitch stainless steel propeller.
- Add Hydrofoil
- Use only ethanol free gas for the last 2 months.
- Checked Compression:
- Top Cylinder Between 135-140Psi
- Middle Cylinder stable 130Psi
- Bottom Cylinder stable 125Psi
I don't know what else to do. I was thinking it might have to do with Timing and Synch?
One odd thing I notice is, when I removed the spark Plugs to do compression test, the bottom spark plug was super clean, compared to the top and middle plug..why?
And only the bottom cylinder will exhaust fuel thru the spark plug hole when I crank the engine to get top and bottom cylinders compression... is this normal? it was giving me 135 to 145psi with all that fuel being exhaust, after I unplug fuel tank and let it exhaust all that fuel, it when stable 125psi.
Also when I wire my tachometer to the bottom sparkplug wire, it will have a lower rpm. like 700-800rpm while the 2 other plug will have 1,500 rpm. is this normal??
The bottom sparkplug wire I replace, its not the OEM plug wire, because they didn't have it at the auto parts. so I used this:
http://www.oreillyauto.com/site/c/de...0063&ppt=C0150
Would this be a problem??
Another thing I notice, the carbs have 2 inlets, one for fuel and one that comes from that choke thing, automatic choke I believe.. well the bottom carb is missing the hose coming from choke. and it looks like it was done intentionally because from the choke hose there is only one splitter that goes to carb 1 and carb 2.... so is this normal?? and what is that hose for??
I cant get no mechanic to help me out because all boat shops in my area are "behind schedule for like 3-4weeks".
have anyone had this problem?
Like I was thinking it could be a timing & sync problem but wondering what is all you guys opinion.
And if any of you know a Timing and sync video for this specific outboard, please let me know.
Thanks
The clean sparkplug is a concern.----------------Find out why that is.----No spark ?--Too much fuel ?---No fuel ?----No crankcase compression ?
interalian
Your bottom wire is a suppressor wire - should be a solid core. Might not have enough conductivity to fire under higher load??
And if you lose speed when you add load, going to a 17" pitch prop from a 15" is a change in the wrong direction
osito2789
Yeah that clean sparkplug worried me too, my tachometer does read a rpm when I wire it to the sparkplug wire. but like I said it have a lower Rpm than the other cylinders.. and my In-Line Spark Plug Checker does get sparks... it could be too much or little fuel... but.. it was exhausting fuel while I was compression testing the other two cylinders...
what's crankcase compression?
jakedaawg
Go back to the old prop. The boat and motor chooses the prop. Not the customer.
Open air gap spark check is next. Technically your compression is out of spec but we will let that go until you post results of open air gap spark check set to 7/16".
jakedaawg
The other issue you may have is a waterlogged hull. Those old glastrons are famous for it. Do you have a soft spot in the floor where it is springy or soft?
osito2789
jakedaawg,
Whats "Open air gap spark check"? Is that the gap between the electrodes? If so haven't check that.. I read they have to be .30?. I bought those plugs from advance autoparts. they gave me the plugs that "matched" the old ones
And nop no water on hull. I rebuild the floor, new 3/4" treated plywood. I always check under plywood to make sure no water is there.
osito2789
couldn't find a wire so small in the autopart stores and that was the smallest one they.. didn't know there was a difference between wires :/ .
emdsapmgr
When you move from a 15 pitch prop to a 17 pitch prop, you need 10% more hp to get comparable WOT tach readings. A stainless prop has more cup and tends to run about one pitch higher than a comparable aluminum, so your 17 stainless runs more like an 18. So, you actually need 15% more hp when changing to that stainless. Agree: Go back to the 15.
WernerF
...Another thing I notice, the carbs have 2 inlets, one for fuel and one that comes from that choke thing, automatic choke I believe.. well the bottom carb is missing the hose coming from choke. and it looks like it was done intentionally because from the choke hose there is only one splitter that goes to carb 1 and carb 2.... so is this normal?? and what is that hose for??...
The choke solenoid has two outputs, one goes to one carb directly. The other output is split and feeds the other two carbs. The choke solenoid is no automatic thing, it is activated when you push the key in. If the hose to the bottom carb is missing, does fuel pour out anywhere when you activate the choke (cranking or running)?
jakedaawg
An open air gap spark checker is a tool. It allows you to hook the spark plug wire to
It on one, the other end to ground. You
The crank engine over and see if you get spark that jumps
A 7/16" gap
osito2789
No it dsent pour out fuel anywhere. Just the bottom cylinder dosent have hose from choke. Is it something i should be worry about?
jakedaawg
Stevens instrument company make a great spark checker. It allows you to see each cylinder at same time and notice both strength and alternating aspects. It's the spark checker the manual mentions.
osito2789
A 7/16" gap
hey where would I plug the other end for ground? anywhere on the engine block?
osito2789
Guys i think i find a issue.
The engine wont start with only the bottom cylinder spark wire connected...
It will start with the top cylinder, barely start with middle cylinder.... But with bottom cylinder nothing.... Is this normal??? And evrytime i remove bottom sparkplug it have a clear liquid on it. Its hard to tell if its fuel or water because evrything smells like fuel. Lol..
I was told that the reason the bottom sparkplug is so clean may be a water leak.
What you guys think about it?
And if water leak, i suppose its fix by replacing gastket? is there any quick fix while waiting for parts?
jakedaawg
Water can clean a plug. Did you check for spark? It's the next step.
sutor623
When you move from a 15 pitch prop to a 17 pitch prop, you need 10% more hp to get comparable WOT tach readings. A stainless prop has more cup and tends to run about one pitch higher than a comparable aluminum.
This is good info right here!!
