Re: 1983 Johnson 115 trim/tilt
82,<br /><br />Is your "trailering bracket" deployed?<br /><br />Look on the right side of the engine (looking from behind). There is a bracket that will hold the engine up.<br /><br />Otherwise, let it down with the manual bleed screw. It is located in a recessed hole on the right side of the engine bracket. Just crack it open slightly, the engine should come down.<br /><br />Also, you have a solonoid box mounted somewhere near the engine. Take the cover off and switch the up and down solonoids, see if that makes it go down but not up.
