1983 Chrsler tilt and trim problem
dsgrubb
Tilt and trim is leaking from shaft that the moter rests on I believe it needs new seals but cannot find any... Any help would be appreciated.<br /><br />1983 Chrysler 90 Charger model# 908v3b
kleeds
Re: 1983 Chrsler tilt and trim problem
Is it a seal or an o-ring? If it is an o-ring take the old one to a local autoparts store, Napa is a good one, and they can match one up. If it is a seal I would try a bearing house such as Kaman Bearing they should be able to find one.
nategarrett
Originally posted by kleeds:<br /> Is it a seal or an o-ring? If it is an o-ring take the old one to a local autoparts store, Napa is a good one, and they can match one up. If it is a seal I would try a bearing house such as Kaman Bearing they should be able to find one.
nategarrett
I am having a similar problem with a '73 Chrysler 70hp. I am leaking hydraulic fluid out the trim shaft. I have replaced all o-rings and still leaks. The shaft appears to be in good shape/no knicks. The outside seal that prevents water from entering is missing. Could this contribute to the leak? I'm thinking about replacing the housing and shaft if I find out the seal doesn't stop leakage. Any help is appreciated.
