1983 Blue Fin 16’ Resto
83bluefin
Picked up a definite project boat off Faceplant Marketplace. Boat, 50HP Johnson, and Calkins trailer package. Probably one of the sketchiest things I’ve done and that’s saying alot. Wife and kids along for the ride and 2 hr ride home with unknown trailer. Kids have a memory at least!
Haven’t looked up the motor info as of yet. From the hood decals appears to be 70’s vintage, manual trim. My experience with other outboards is that you should be able to spin the prop in neutral….yeah can’t do that. I was told it was running last season and judging by moving the manual choke on the motor and smelling gas it’s probably correct.
Boat is a total project. Previous owner ripped up the floor and replaced it with what he termed “plastic” screwed down. I’m not impressed as it’s slippery, can’t anchor the pedestal seats that the boys want to it, and being honest I didn’t do it so questionable as to what is underneath. That and I want to do a coat or two of Coat-It or Fasco epoxy…still in the air on that…looking for a cost savings over Gluvit.
Beauty panels are ripped out to unknown locations and electrical is a mess.
Will post pics soon.
83bluefin
Started the other night on the trailer. Redneck heaven I swear. Connections with wire nuts, duct tape, and spade connections. It’s a wonder the tail lights worked…I had brought a Harbor Freight wiring harness with me on pickup just in case.
Ran wiring down the drivers side rail of the trailer and added brackets for marker lights. Going full LED with home runs to ground on each light. Not trusting a bolted trailer to give me good grounds.
Going to have to replace the tires as they’re unknown vintage.
roscoe
Congrats on the new adventure.
That hull was made by StarCraft- sylvan-smokercraft. It should be a good one.
16’ or 18’ - ???
ALSO—- Go to the StarCraft forum for detailed information on your project.
MikeSchinlaub
From your description of the floor, I would guess it rotted out and that was his "fix". I would first plan on a total floor and transom replacement. Lucky for you it's an aluminum hull, so no wood stringers.
redneck joe
And some, or hundreds, of rivets.
If you want to get this thread to the starcracft area, just ask a mod to move it.
83bluefin
Right now I think the transom is OK. It ends above the floor and after yanking on the outboard with the tilt locked in the upright position the transom showed no movement whatsoever. I’ll let the marina make a final decision once I get to the point where I’m ready to be concerned about a motor. Worst case…I’ll get some Seacast and pour a new one. I really only want to do this once.
Learned the motor is a 71…50ESL. From reading I’m doing the motor has to be spinning to shift gears and defaults to F when power is cut. Since that’s the case, I have 0 interest in finding out if it runs. With at least 2 Bubba’s worth of electrical hacks, I have no interest in putting power to this before I rewire. Trade in fodder unless I get overly ambitious and pull it off the transom myself at which point it’d go up on FB marketplace. This is a purely no-smoking section. Yammie or possibly Honda if the boat can carry the extra weight…have yet to find a capacity plate. I’ve seen similar vintage boats with up to 90 Rudes on them.
It’s a 16’ and I may have tracked down a full 3 piece window for $40. Trying to pick that up tomorrow.
Floor was getting ripped up as it’s not right. It looks shimmed up from the stringers based off a small section we pulled up. Also looks like there was a tie piece between the faces of the stringers which isn’t there now…rivets are still in the holes suggesting structure was removed. I’ll add some back when I’m ready to do the floor. May explain the leak we found in the front of the boat.
Focus has been on the trailer so I can move it. Tires are all dry rotted. Man I dodged a bullet there. By all means they should have exploded on the trip home.
Weather should be nice enough tomorrow to bang out the wiring so I have tail lights again. IMG_8643.jpeg
83bluefin
May not look like it but left turn signal/brake, 3/4” marker in front of the tire, and marker up near the winch stand are wire in. Ran out of day light so couldn’t get to the other side.
My youngest isn’t a fan of the 3/4” marker. When I tested it he asked if I was trying to blind him as it was soooo bright! I told him that was the point so other drivers could see the trailer.
Need to get over the wiring hump to get back to painting the trailer and then getting the new fenders installed. You might see them behind the boat…aluminum diamond plate from Runnings. Only local place that had a set.
Still need to address the keel rollers. Front most one…cap was off and pin is partially out of the bracket. Last one is partially split as well. New caps, one pin, and all new keel rollers on hand for swap.
airshot
This boat is a 1983, some 45 years old. The wood in the transom was never sealed at the factory, so.....if you created a good plywood transom that is sealed.....are you going to have that boat for another 45 years ? Probably not, so why go thru making a cast transom ? Many folks doing a restore want it to last forever, but as we all know, life changes! Odds are this boat will be replaced long before a new transom fails.
redneck joe
What is a 3/4 marker?
My 82 transom is factory, I've taken an ice pick all over it and it is solid.
airshot
I believe be he was referring to the side marker lights on the trailer. Floors are easy, glad the transom is solid !
83bluefin
3/4” round marker…the little dot ahead of the wheel.
As for the boat…it’s a father/sons project. My oldest can get his boaters cert next month so…yes, this boat will probably be in their hands for long after I’m gone.
One of the other reasons I’m willing to spend big $$$$$ on a new engine for it.
As of last night the trailer is completely wired and tested. Only need to add a small piece of split loom where the wiring leaves the tongue and goes into the side rail (behind the spare tire).
So onto paint and mounting the fenders. Gonna take some spacers off the existing mounts…maybe…possibly. I have a set of mounts for plastic fenders which do not fit the trailer as it sits. Tires are too wide. My guess based off age of the trailer is that it had the skinnier 13” rims but somewhere in its life someone swapped 14” rims. Gonna run what I have unless the fenders really put up a fight going on.
airshot
Side marker lights have changed a lot over the years. With the introduction of LED lights, a tiny little 3/4" dot can be much brighter than a 2" x 4" rectangle. I have those small 3/4" dot lights on my enclosed trailer, and yes, they are bright !
Bugzilla46310
I’ve used the True Mods 3/4” lights. Very inexpensive and bright. When I get around to repainting the boat trailer I will convert to them. Made this below the tailgate driving/3rd brake light with them.IMG_1197.jpegIMG_1198.jpegIMG_1199.jpeg
83bluefin
Weekend progress. Got the outer side of the rails and most of the tops in blue. Pain doing it with aerosol (seems its always windy) so going to switch to quart & paintbrush for everything that remains.
Up next are fenders. Admiral says no to striping trailer or putting Calkins back on it. May make an appearance anyways…looks to blah without striping or the name. Going to have to stamp the VIN on the trailer as the VIN tag was sunbleached/unreadable.
Admiral is working slowly on removing the striping on the starboard side. She wants to get it to a point where we can paint it. I have repop decals coming in Navy Blue which has gone through the formal approval process.
Keen eyes will note the windshield under the boat. $40. Needs some refinishing and may involve some work getting it mounted properly. Going to pop off the slip on snaps, sand, etch, then set in black chrome Rustoleum. Shouldn’t be too terrible beyond the masking. All flat glass so I have that going for me. Will worry about mounting it once I get the front floor under the consoles re-done.
airshot
Just curious here....your wife doesn't want any trim or decals on the trailer, so does she know something we don't...such as mabey the fish won't like the decals, or it might scare them away ?? We would like to know her secrets....lol.....
MikeSchinlaub
You can take those apart, just make sure every screw goes back in the same hole. Some of them are in line with the glass, so if long ones go in short holes you can shatter the glass. It's not something I've done myself, but I've seen it done right by the supervisor and wrong by a former coworker.
83bluefin
You mean I’m supposed to keep the trailer attached to the boat when I launch? ;)
I found a place that will direct print in Carbon Fiber or other. Fairly cheap too.
Q: the gaskets on the window frame where the side frame meets the front frame (3 screws in the front frame secure it to the sides)…the gasket is shot. What would be a good replacement? I was thinking cut down bicycle inner tube as it’d be thinner than foam weather stripping. Caulk? Other?IMG_8658.jpeg
Same for where it’s mounted to the boat…what gasket material to use?
MikeSchinlaub
Windshields often dont even have gaskets on the mating surface. You could put a bead of silicone down if you want.
83bluefin
Fender mockup. Used 1x2 pvc trim cut to 5” long as a spacer on the stock brackets…cause mainly I’m lazy and don’t want to try to remove them. There…I said it :)
Going to use ss buttonhead bolts and nylock nuts to hold everything together.
Admiral has relented on the lack of striping on the trailer…as long as it’s black. Found black carbon fiber striping which will tie in with the direction we’re heading with the boat. Steering wheel is junk and found a new one within budget that’s black carbon fiber. Console dashes are awol so will wrap a piece of aluminum in black carbon fiber to tie in with the steering wheel.
