1983 bayliner
rickcamp10
Took boat out for first time starts and runs great but motor will not get over 3000 rpm to plane out motor does not bog down or stutter 1983 bayliner aq125a on a hose it will rev 4 to 5000 rpm but not under load any help will be appreciated
GA_Boater
Running on muffs proves nothing because there is no load and high RPM's on muffs can cause damage.
Start with the basics - Compression and spark test. Try fresh fuel and probably change the fuel filter.
rickcamp10
There is no fuel filter and the tank was emptied and filled with fresh fuel and have plenty of spark have not done a compression test
GA_Boater
Also moved this thread into the V-P section.
One more thing to check is that the carb(s) butterfly is completely open when the throttle is maxed.
stickies at the top of the forum have a bunch of reasons why you would have low WOT. use it as a troubleshooting guide.
rickcamp10
I know what you mean now i' m new here thanks a lot will check into every possibility
