1983 19ft conroy boat with cuddy cabin
donaldjoyner
i bought a 83 19ft conroy cudy cabin boat for a hundred bucks with trailer,the interior needs redone and the center of the boat floor is roten so,but i got the motor the start and the trim works.the boat has a omc inboard/outboard 3.0,i was just woundering if these boats were worth fixing up and what would it be worth
thanks
AlmostFamous
Re: 1983 19ft conroy boat with cuddy cabin
Hi, I believe you will find the common answer to be no and very little.
The reason being, it's a ton of work, I mean a ton, to gut the boat and lay down new stringers, transom and a floor. Then your left with a boat powered by an OMC, which they do not make anymore and some parts are hard to or impossible to find. $100 bucks....you did ok, part her out and move on. That's my .02
pmillar
The fact you have a running, hard to find parts for drive train may actually work to your advantage... in the form of higher part prices if you decide to part it out.
ezmobee
Wouldn't be my first choice for a resto project mainly due to the OMC drivetrain.
