1982 Starcraft w/ 50hp
Jayb123
Hey again all....
This might be the one...
$1200/neg with a 50 HP
if all checks out.. would a 50hp be strong enough to have 4 adults aboard and tow a kid on a tube?
O and a big HAPPY MOTHERS DAY TO ALL THE MOMS ABOARD :D
Thanks :D
Alumarine
Re: 1982 Starcraft w/ 50hp
If that's a 16 footer I think you'd be happier with a 70hp.
I'm sure there's a few guys with the same rig that should know though.
Bob_VT
Ahhhhh nice SuperSport !!! You should not have any problem tubing with that at all........ if you are desiring to water ski then it might be a bit low on power but doable.
Jayb123
Ya Bob.... Its only to pull my one of my boys tubing at a time... no skiiing here :)
As long as I can have the 4 adults onboard and pull a tuber. I would like to have a 70hp. But for now I wanna see how the 50hp performs. I might upgrade later in the future. I guess if I need to find a benefit of the 50hp.... is lower gas comsumption :D
Home Cookin'
I grew up with the 16' starcraft w/ a 55. Did fine for skiing, tubing, etc. w/ 4 teenagers on board. We were smaller then, though. Loved that 35 cent a gallon gas!
Jayb123
One last question.
After reading threads about fiberglass and aluminum hull boat restorations. *Generally speaking* when fiberglass boats have soft floors....they will have some part of a soft stringer or transom. Similarly, when reading aluminum boat resto threads I have noticed corrosion can be present. Since I cannot see the inside of the transom .... are there tell-tale signs I might be able to look out for while inspecting? Would an indicator of corrosion in "said" area be a walk-away indicator... thanks as usual :D
ezmobee
The ones we've seen with corrosion issues were generally used in saltwater and were also in overall pretty rough condition. I would be extremely surprised if that one had issues with corrosion. That's a very nice price and I think the 50 will be fine for you at least till you feel like upgrading. Good luck!
jasoutside
Thant one looks like a winner right there! Price seems about right even if you need to rebuild er. Anything less is icing on the cake!
Have fun:D
Huron Angler
The picture is kinda small, but I like that rig...a lot! :)
Folks have run 50hp outboards on 16' Starcrafts, and if it's running well it'll plane out the boat just fine. Speeds have ranged from 25mph up to the 30s. I think one guy ran a newer Yamaha 50hp and saw 35 if I remember correctly.
Not a bad price either, but feel free to talk him down to $900;)
Jayb123
Its sold already.. lol.. I give up.
Anyone in the house have and extra innertube i can float around in this summer (as long as it holds air im fine).. Ive got my own pole and gear.. thanks... :)
