1982 Sea Ray Ski Storage
drewmitch44
Re: 1982 Sea Ray Ski Storage
That boat looks just like mine except your is the i/o. Nice boat! LOL
pigrge
Go Big or go home, thats the way that I think of this boat. After an ENTIRE weekend of tearing out old rotted wood and wet foam, I have decided to just go ahead and replace the transom, as well as the motor mount, and rewire the boat. I have to yank the motor to do all tihs of course, but ohhhh welll. One BIG question that I have is why in the world would Sea Ray fill the voids with all that foam, and then not seal the holes? This make NO sense to me. The holes in the deck that they used to fill the voids were just capped off with a little bit of foam and that is all!!!! This is odd!!!/ Once more question....when I pull the motor, how should I measure that front mount for replacement of the motor? Is this crucial? I feel that I want this measurment to be VERY VERY accurate!!!! Any ideas? Thanks in advance for any advice!
Coors
boat manufacts go cheap.
once engine bolted to transom, easy to mark, unbolt mounts, and drill.
All this is relaxing, as it gets your mind off work.
mtnrat
If you search threads started by me in this section you will get a lot of info. I ended up redoing the whole boat with the help of those here. Good luck.
pigrge
I have little room for all kinds of bracing for my boat when re-doing this project, so what would be the procedure for doing the stringers and transom without bracing?
pigrge
Hey Again Fellas!
Okay, I have searched and searched and searched and could not find anything as to the order in which to replace these stringers and transom. As mentioned before, I do not have the room to remove the boat from the trailer, so I am hoping that I can do this whole procedure without removing the boat from the trialer and put all kinds of special bracing on it. So if someone could please chime in with some experience!!!! It would be greatly appreciated.
Also, this being a small boat, 16.5 ft. total overall length from bow to stern without the outdrive, I am looking at putting storage under the deck. Anyone have experience with this? Should I just make plywood boxes and wrap them in glass and glass them into the deck? This would be a tremendous help! As this is a closed bow boat as well!
One more thing before I begin this prcess of putting things back, when I removed the decking before, I looked at how it was put in and it actually has glass running from the underside of the deck to the top of this stringer and NOT glass running from the bottom of the stringer to the hull of the boat!!! Almost as if the glassed the deck to the top of the stringer BEFORE putting it in the boat??!?!? This is normal? I would think that the strength should come from the stringer to the hull. Thus glassing in the stringer on both sides to the hull. BUT how to attach the stringer to the deck then? This is the procedure that makes me scratch my head!!!!! I know this post is long, and I apologize, but any help is appreciated!
pigrge
Anyone have any input on this?
