1982 Mercury 40HP water pump
lilcwgrl
I need to remove my water pump, however, I am not sure where to begin. When I take the screws off the bottom part of the shroud beneath the motor will this allow the shroud to drop out of the way of the water pump?
Thierry Netten
Re: 1982 Mercury 40HP water pump
my water pump has been removed and when the last ownier tried to reinstall, he has problem with a shaft.
That's why i'm looking for maintenance manual before desinstall the water pump out of the engine.
Kirscher
Your 40hp is probably similar to my 35hp. Read the great response I received. It took me less than 1.5 hrs to install a new impeller.
