1982 Johnson 9.9 thermostat
Matt Mann
Does the 1982 Johnson 9.9 have a thermostat? Just bought the engine. There is a pee / telltale hole under the cowling, but it never pees. I can see a tube going to it from the engine block. There is water coming out of the exhaust thing on the mid/lower unit, but none from the pee hole.
Vic.S
Re: 1982 Johnson 9.9 thermostat
Yes it has a thermostat part #19 in the diagram HERE
The tell-tale may well be just blocked. Check the outlet nipple, the hose and the elbow were it connects to the engine. Take care not to break plastic parts!
You will find stacks of useful info at http://www.sschapterpsa.com/ramblings/Ramblings.html#OMRA
For an engine that is new to you follow the advice for recommissioning an engine that has not ben used recently at http://forums.iboats.com/showthread.php?t=158086
