i did just buy it but it has been sitting for a year. we put carb cleaner and it runs when started but super hard to start. No i have not checked the gear case oil.You need to post much more information !--------Did you just buy it ?----------Have you checked gearcase oil ?-----Did it suddenly get hard to pull over ?
Yea it runs fine. It pulls easy with plugs out so i guess its just a hard motor to pull.I have an 30 hp johnson. These bigger two cylinders can be quite hard to start by hand. You will have to put al lot of effort in it. Especially if you are used to smaller outboards. However, something can be faulty. Try to remove the plugs and than cranck it. It should be easy. If so, your engine is fine. If it is still hard to crank it you might have a problem with the recoil starter or worse. But does the engine run good? If the engine is in overal good shape, it should take 2 or three good pulls to start it.
I don't think the rope needs to be placed. I guess its just the engine size that makes it hard to pull.Just looked in my service manual. It talks about timing marks on the rope starter. There's an arrow on the disk under the mounting bracket that rotates when you pull the rope. That arrow is suppose to point between 2 marks on the mounting bracket when the rope is completely wound up. Looks like the bracket has to be off to see the marks. Or maybe you can see them with a small mirror. Not sure what the timing does but maybe the rope was shortened at some point. If you need to change the rope post the question on this site because there's a simple trick you need to know.
